New Topic New Reply
Author: Subject: Tight Fit Rad pipe
SteveO
posted on 29/7/03 at 08:44 AM Reply With Quote
Tight Fit Rad pipe
Need some help on this one folks, i have an Indy and can't see how to route the pipe from the lower outlet of my radiator. The problem is that its an L-shape outlet facing upwards and the connection to the water pump will go through the alternator/w-pump belt. will SVA man like this?
How have some of u guys done it.
bob
posted on 29/7/03 at 09:56 PM Reply With Quote
STEVE
Pinto water pump is 1 and 1/2 " outlet so has to be reduced to 1 and 1/4 for escort rad.
I've got a piece of pipe out of pump that is reduced to rad size and joined (via ally pipe and clips)to a flexy pipe bent in dog leg towards rad running under the steering rack.
Pipe is dead tight under rack but i've seen it done elsewhere.
You have u2u
cheers
New Topic New Reply
