LBMEFM
| posted on 18/4/07 at 07:12 PM |
Build Questions
I have three questions that maybe someone can kindly help with.
1/ The manual says that the rear brake flexis are fitted to the welded bracket, I cannot find one on my chassis?
2/ The manual says the steering rack is mounted on the support plates, what plates?
3/ The four bolts I took off the doner to mount the rear hub carrier to the upright seem very tight in the pre-threaded holes on the MK chassis, I
don't want to put too much pressure on them and shear them off. Are they the same thread or do the holes just need cleaning, maybe powder
coating in there, anyone else had this problem.
LBMEFM
| posted on 18/4/07 at 07:20 PM |
Missing Brackets
Thanks Chris for the quick reply, what do I have to do if the rear fklexi brake pipe brackets are missing, do I get new ones welded on?
ReMan
| posted on 18/4/07 at 08:04 PM |
None on mine, did'nt expect any though?
Made some like so....
stevec
| posted on 19/4/07 at 08:12 AM |
Here is how I did my brake hose brackets.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=P1010203.JPG
DRC INDY 7
| posted on 19/4/07 at 05:25 PM |
I have done mine the same with bent alloy brackets simple
Puddle Dodgers Club
