Pezza
| posted on 2/5/07 at 05:51 PM |
Actualy did some work + steering rack question
finally did some more work on the Indy today.
Rebuilt the calipers with service kits
Got the master cylinder bolted in and ran the rear lines.
Using one from a nissan from the scrappy, nice lightweight joby.
Have to see if it's up to the task with sierra disks though.
Now a question for you guys.
I remember reading something about the steering rack having to be collapsable or something for sva.
That's what i've got in mine, but I removed the corrugated sleeve at the top to fit one of pathfinders paddle shifts.
Will this still be okay?
Ben
[Edited on 2-5-07 by Pezza]
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
novacaine
| posted on 2/5/07 at 07:04 PM |
the corrugated bit is the collapsable bit that is required for SVA, but there is still hope
you can get away with offsetting the colum by IIRC 17 degrees, which judging by your pics might be ok (please correct me if im wrong about the angle
hope that helped
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
AdamR
| posted on 2/5/07 at 07:15 PM |
There are two collapsable features on the Sierra column (assuming that's what you're using). If you still have the telescopic triangular
section then you may be covered.
[Edited on 2/5/07 by AdamR]
Pezza
| posted on 2/5/07 at 08:44 PM |
yup got the telescopic bit if I remember correctly.
Cheers chaps
worX
| posted on 3/5/07 at 05:26 AM |
should be ok with just the one collapsible part that is visible in your pic...
are you running Two brake lines to the back of your car?
Steve.
Pezza
| posted on 3/5/07 at 08:36 AM |
Yup, the mc is a duel cylinder jobby, 2 outlets to both front and back.
Very light weight though, about a quarter of the sierra cast mc
Pezza
| posted on 3/5/07 at 02:38 PM |
Got the rest of the hard lines p-clipped in and brackets in place.
Where is a good place to get braided flexis from? need to be sva compatible.
Ben
[Edited on 3-5-07 by Pezza]
zxrlocost
| posted on 3/5/07 at 05:16 PM |
have you got the body on yet
zxrlocost
mad-butcher
| posted on 3/5/07 at 05:29 PM |
can't see if resevoir has an electric low fluid level indicator.
Tony
Pezza
| posted on 3/5/07 at 10:26 PM |
Yup it's on the offside of the cylinder
Not even ordered the bodywork yet, need to flog the rover 200 to release some funds first hehe. Lines are in place to go through the side panels
though.
zxrlocost
| posted on 3/5/07 at 11:10 PM |
sounds like me sell anything important to buy good stuff
Pezza
| posted on 3/5/07 at 11:45 PM |
indeed still got a grand sat in the bank for the engine, malc is hunting me one down, but the carb'd r1 seem more rare now.
Selling the rover will get some of the other expensive bits out the way, plus i'm reclaiming bank charges which will hopefully fund the rest
