Toady1
posted on 3/5/07 at 05:15 PM |
kill switches
when the engine is running, is the kill switch circuit 'open' or' closed'? I was thinking closed....
John Bonnett
posted on 3/5/07 at 05:31 PM |
It has to be closed to make the circuit.
blakep82
posted on 3/5/07 at 05:43 PM |
i thought kill switches were open, and closing shorts out the ignition? at least thats how it was on my lawnmower...
________________________
Toady1
posted on 3/5/07 at 05:52 PM |
im not too sure...but i need to find out! lol!
esn163
posted on 3/5/07 at 05:56 PM |
Hi
looking at our earlier blade haynes manual when the switch breaks the circuit one of the feeds (or earths) to the coils and ECU is broken. It looks
like run position is when the switch completes the circuit but I could be wrong..
HTH
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
mark chandler
posted on 3/5/07 at 05:59 PM |
Closed to run on on the main bolt on terminals.
On the smaller connectors you have a two, one is closed ignition off (this grounds the engine side to earth via a resistor to stop the alternator
running the engine), other closed on run goes off towards the ignition/efi feeds so powers the engine only. Do not also feed the lights etc through
this or it will burn out.
Regards Mark
Toady1
posted on 3/5/07 at 07:25 PM |
mark - could you re-explain that plz i didnt quite understand?![](/images//smilies/tongue.gif)
ChrisGamlin
posted on 3/5/07 at 07:50 PM |
I think Mark slightly got the wrong end of the log and is talking about an FIA kill switch as used in racing cars etc, which has one big set of
terminals for cutting the main +ve lead, then two smaller pairs to cut electrics etc.
Anyway, from my notes on starting the 919, the stop switch needs to be closed to fire.
[Edited on 3/5/07 by ChrisGamlin]
Toady1
posted on 3/5/07 at 07:52 PM |
oh right, cheers.
Still not got a spark tho, I dont have my fuel pump connected up as tank isnt in yet, that wont have anything to do with it would it? I dont think
there are any fuel pressure switches....
Toady1
posted on 9/5/07 at 08:34 PM |
just to clarify this...Ive sorted my no spark prob now!
Kill switch has to be closed to run.![](/images//smilies/cool.gif)
