matthewdrummer
| posted on 6/5/07 at 07:11 PM |
tyre lossage
Ive swiched from my 17" to 15" all black team dynamics 15" with toyo r888 but the rear left tyre is catching when i hit bumps on the
wheel arch. I have checked all mesurments i could think of to see if the wheel arch is odd but both are in the same place on each side. I have had to
higher the ride high for now. I am wondering if they are odd molds or somert. any one had this problem.
| posted on 6/5/07 at 07:20 PM |
Our R888's rubbed the rim of the wheel arch when we first fitted them. We removed about 5mm of the return edge on the arch and have 1.5 degrees
negative camber. The tyres no longer rub.
Have you set your camber on the rears?
Phil
[Edited on 6-5-07 by Hellfire]
