Colnago_Man
posted on 18/5/07 at 07:22 AM |
Prop alignment on Indy?
Morning Indy fans.
Last night I started to test fit my prop, looked okay but I was a bit worried about the angle and the position of my sprocket adapter. If I look down
the tunnel towards to engine my sprocket adapter is only half visable, the rest hidden by the curved part of the foot well panel.
Therefore the prop turns quite sharply at the centre bearing then just missed the footwell plate by 2cm.
Is this too much of an angle on the centre bearings?
Thanks.
posted on 18/5/07 at 07:27 AM |
Sounds alright to me...
Howlor
posted on 18/5/07 at 07:37 AM |
Bob on.
Danozeman
posted on 18/5/07 at 09:22 AM |
Perfect. It doesnt want to be dead straight or the uj's will wear out quickly.
Dan
cadebytiger
posted on 18/5/07 at 11:05 AM |
not an expert but when we had out prop made they said make sure you don't run perfectly straight so sounds like you got it right
