mkblade
posted on 29/5/07 at 10:44 PM |
wiring RX1N
help needed ,with the above please i know a couple of you guys have wired this up now so im trying to get as much info so i can have a go at it at
weekend.
you get all the sensors in the kit, i already have the sensors in the engine ie temp sensor, electronic speed sensor (blade) with the speedo healer do
i do away with these sensors and fit the ones in the kit?
many thanks simon
vorn
posted on 30/5/07 at 07:13 AM |
CaLviNx you say you found the rev counter a bit too small , did you have it on your dash ? I have got one and thought the same so I thought I would
mount it on my steering column behind the steering wheel to get it closer.
Do you have any pic's of the koso mounted in your car??
Vaughan
RichieC
posted on 30/5/07 at 08:15 AM |
quote: Originally posted by CaLviNx
My RX1N gauge was found to be reading to within 99.9% throughout the speedo range at SVA earlier this month. its a really simple thing to set up
too.
if you place the magnets on the prop the fastest way to setup is to find out the circumference of your wheels say for example 1297mm take that figure
and divide it by your diff ratio which for example is 3.62, which gives you a figure of 358.28.
you then pump in the figure 358 into the koso gauge as well as the amount of magnets you installed and bobs your uncle
[Edited on 30/5/07 by CaLviNx]
What size tyre is that for CaLviNx?
Yup agree with all of the above, it really is an easy install and works a treat. I also found the fuel gauge the most accurate and easy to setup on
many aftermarket dash.
Rgds
Richie
zxrlocost
posted on 30/5/07 at 09:36 AM |
hi mate I repeat whats already said dont cut any corners
kastrato
posted on 30/5/07 at 06:22 PM |
Ok it is about time to make myself look stupid.
I have no experience of fitting anything to any car so does anybody knows a good workshop or garage which will able to fit the RX for me?
I leave in huddersfield.
I am afraid that if I try my self I will destroy it. Plus all these seems greek to me.
(that is why I bought my blade indy and I did not make it myself)
MK INDY fireblade
kastrato
posted on 30/5/07 at 07:07 PM |
I know that is why I said it ... lol
MK INDY fireblade
mkblade
posted on 30/5/07 at 10:19 PM |
thanks everyone for the info i will be getting stuck in to the wiring on sunday going to brands hatch saturday so may well see some of you there
simon
kastrato
posted on 31/5/07 at 01:01 AM |
Are you going to Brands for the westfield day?
I might go too. Not with the MK though cause it is 400 klm from Huddersfield...
MK INDY fireblade
