scoobyis2cool
posted on 15/8/03 at 04:21 PM |
Quick master cylinder question
Should i mount the M/S with the reservoir vertically above the cylinder or will this interfere with fitting anything else? Just wanted to check before
i go drilling holes!
MK Goldrush
posted on 15/8/03 at 04:43 PM |
Mast. Cyl.
I believe if you fit the MS as per car. It's a bit of a (eh-hem!) 'devil' to fill as it's so low down. I understand it's
obstructed by steering linkages when filling from above using standard means. I've been asking similar questions Scoob to clarify how it couples
to entension tubes...
We wait in patience (or is that patients?)
