scoobyis2cool
| posted on 17/8/03 at 12:37 PM |
Fitting rear dampers
When fitting the rear dampers (and probably the front ones as well) there is a large gap between the damper and the mounting plate, what do i use to
fill this?
mad-butcher
| posted on 17/8/03 at 01:18 PM |
washers unless you've got a lathe
same as the ones supplied with the bolts 2 either side
tony
scoobyis2cool
| posted on 18/8/03 at 11:56 AM |
How much play should i have between the damper and mounting bracket? Should it be a tight fit or should i be able to move the damper slightly? Does
this change once i tighten up the bolts?
Jasper
| posted on 18/8/03 at 01:48 PM |
Snug is best, the damper usually has a rubber mounting anyway.
