paulmw
| posted on 13/6/07 at 09:21 AM |
What Bolts
I am struggling to find what size of bolts/nuts I need :
- Bolts which connects the steering rack to the connecting shaft
- Bolts which attach the rear hubs (disc) to the rear hub carriers
- Master cylinder to the bulkhead (I also presume you need to drill holes)
- Also what size P-Clips do I need
bob
| posted on 13/6/07 at 09:54 AM |
I'm pretty sure my rear disc set up is held onto the hub carrier with M10's
Not sure what M/Cylinder you are using but mine is held on with M8's
As for the rack i presume you mean the lower down link from the steering column, sure its M8 as well.
Remember to use high tensile 8.8 minimum strength.
hope this helps
