paulmw
posted on 16/6/07 at 09:24 AM |
Ball joint
Having just fitted the front hubs I cant seem to tighten the nuts on the top and bottom ball joints. They just spin around, I am doing something
wrong?
stevec
posted on 16/6/07 at 09:29 AM |
Put a lever in underneath to put pressure on the taper to stop the threaded part turning and that should sort it.
Steve.
paulmw
posted on 16/6/07 at 09:36 AM |
Sorry Steve, I'm not sure what you mean.
Push the treaded bar into the housing?
stevec
posted on 16/6/07 at 09:45 AM |
Sorry my description is a bit vague,
To stop the pin turning you need to put wieght on the taper, so you need to find a way of pushing the hub part down on to taper by leaverage or
putting a jack under it,
Is that any clearer?
Steve.
posted on 16/6/07 at 09:58 AM |
Find a plain nut and tighten it up with that first to lock the taper, then use the nyloc to secure it. If you are going to be taking it apart and just
trial fitting leave the plain nut on till you are finished.
