david cromie
posted on 19/8/03 at 11:55 PM |
fixing mk silencer to chassic
what method is the best for securing the silencer to the chassic. david
Rorty
posted on 20/8/03 at 04:10 AM |
If you weld it on, it shouldn't come off!
However, it may well crack the welds after a while, so you'd probably be better off mounting it with a couple of silencer bands to a couple of
those rubber insulators. They have independant threaded studs poking out each end, so you can stick one through a bracket on the chassis, and the
other stud through the hole in the band.
Industrial supplies outlets are the typical source.
Cheers, Rorty.
loafersmate
posted on 20/8/03 at 04:44 PM |
I went to an exhaust fitters and routed through their rubber mounting brackets till I found one for the job! I have an MK exhaust with the small tab
welded on the end of the silencer.
Ben
david cromie
posted on 20/8/03 at 11:54 PM |
fixing exhaust
tks. again for your help. david
mad-butcher
posted on 21/8/03 at 06:01 PM |
this months which kit part 4 of the mk indy build covers just this point with a great picture martins website are covering the build so there might be
a pic on there
tony
GaryM
posted on 16/1/06 at 06:05 PM |
When you say Martin's Website can you provide the address as I can't seem to find it?
Gary
posted on 16/1/06 at 06:43 PM |
Probably cos it's not there anymore This thread is two and a half years old.
