eccsmk
| posted on 25/6/07 at 10:05 AM |
newbie question
im looking at buying an mk indy kit and have found a donor car but it is at a local scrap yard so will have no chassis numbers log book etc. will this
cause me any problems when sva time eventually arrives??
many thanks for any replies
update im going over to mk tomorrow hopefully ill be ordering my first ever kit car
[Edited on 25/6/07 by eccsmk]
DavidM
| posted on 25/6/07 at 10:09 AM |
Shouldn't be a problem. Just make sure you get a receipt from the scrappy. You'll then need to get proof of engine age for the SVA
emissions test. DVLA will give you a Q plate if there is no donor logbook, but will still want to see the receipt to satisfy themselves that the donor
parts aren't nicked.
mike smith1
Wont cause you any problems at sva time, it will just mean that once you come to register your car you will definatly get a Q plate.
Oh and welcome to the mad house!
What engine are you going to be putting in?
Mike
fesycresy
| posted on 25/6/07 at 10:11 AM |
Give it a miss - still relatively easy to finding a Sierra that's still on the road.
SVA no problem - not an issue
But it's when you come to register it for an age related plate, it'll be easier with a log book, chassis plates etc etc.
Good luck.
eccsmk
| posted on 25/6/07 at 10:19 AM |
engine wise ive been offered a crossflow and a (hope this is right) cbr 1000
i might have a look around for a sierra with log book see what appears
many thanks
zxrlocost
| posted on 25/6/07 at 10:45 AM |
if you have no receipts mate its no probs
| posted on 25/6/07 at 11:24 AM |
many thanks
Wecome to the nuthouse. Whatever you do, make sure you go for the bike engine.
Phil
Macbeast
| posted on 25/6/07 at 11:25 AM |
If you want to, you can always take off the two identification plates by the bonnet release and (this is more difficult ) cut out the chassis number
which should be stamped on the floor at the driver's right side.
eccsmk
| posted on 25/6/07 at 11:34 AM |
ive been in touch with someone who has a car sat in there drive with all paperwork for £100 might be worth a ride over make my life easier anyway.
engine wise how do you connect the bike engine to te sierra prop ??
zxrlocost
| posted on 25/6/07 at 11:38 AM |
hi with a sprocket adaptor so you take the sprocket off and put this adaptor on
| posted on 25/6/07 at 11:42 AM |
Like Chris says.
Have a look on our website. It should give you some idea of how a BEC goes together.
Phil
StevieB
| posted on 25/6/07 at 11:44 AM |
You'll get a sprocket adapter from MK (or most of the manufacturers) that will connect the bike engine chain sprocket to the prop shaft - dead
easy to do.
If you haven't been out in a bike enigned car before, make sure you do so before deciding which engine you want - the performance is astounding!
