afj
| posted on 19/8/07 at 06:25 PM |
suck or blow
orderd a polo rad what fan do i need suck or blow mounted in front or rear (near engine) ta alan
speedyxjs
| posted on 19/8/07 at 06:27 PM |
Im not sure that it matters too much but i maty be wrong
worX
| posted on 19/8/07 at 06:32 PM |
It only depends on what you have room for.
If it will fit behind then you need a Pull, and if you want it in front you will need a push.
I was always having mine in front to give the Rad a little extra protection...
You could always buy a reversible blade one and therefore decide at a later date!
hth
afj
| posted on 19/8/07 at 06:35 PM |
sounds like a plan thank you alan
RazMan
| posted on 19/8/07 at 10:15 PM |
Personally I prefer a 'puller' to keep the airflow to the rad as undisturbed as possible.
Raz
| posted on 20/8/07 at 07:41 AM |
Rimmer brothers have a batch of very cheap electric fans
| posted on 20/8/07 at 08:49 AM |
I've wondered about this .... but then the air flow will be disturbed behind the fan.
I was told by someone who is very much into cars that a push fan is better, reason given a puller can never pull more then 1 atmosphere wheras a
pusher can go much higher.
