jabbahutt
posted on 23/8/07 at 12:42 PM |
holding in place
Hi again
Further to my recent question about suspension. What methods have you guys used to hold an arch in place before fitting to see if it looks right?
I've tried spring clips but cant get then in with the wheel fitted.
I'd obviously like to look at the arch in position from different angles before comitting to drilling plus in held it would be easier to finally
drill and fit.
Nigel
gezer
posted on 23/8/07 at 12:55 PM |
you could try a couple of blocks of wood connected together with a foot of string, on top of the tyres, with some thin ply to shim them up so you can
step back to see what they look like ?
I'm to old to live and to young to die --- buggerit
nib1980
posted on 23/8/07 at 01:22 PM |
what about double sided sticky tape, should do temporarily?
Benzine
posted on 23/8/07 at 02:14 PM |
2 mole grips worked for me
speedyxjs
posted on 23/8/07 at 03:09 PM |
Or get someone to hold them while you look
Just make sure they have a steady hand
afj
posted on 23/8/07 at 04:49 PM |
gaffer tape you can do everything with gaffer tape
posted on 27/8/07 at 10:13 PM |
you can roll duck/duct tape back on itself to make a good double sided tape.
