New Topic New Reply
Author: Subject: Not a happy Bunny :(
Adam
posted on 1/9/07 at 03:54 PM Reply With Quote
Went across to MK today to drop off some stuff to get modified so we can get cracking. First off was told the UJ linkage was the wrong wrong! our car had powered steering. Then the prop was the wrong one it came off a 2.0 1991 Ghia but for some reason it was wrong. Any idea where i can get the parts from..... the correct ones. I just want to get everything together so i can make a start.
any help would be much appreciated.
Adam
posted on 1/9/07 at 03:56 PM Reply With Quote
MNr can supply you with a brand new bespoke prop shaft rather than modifying an ancient donor one
Jimbob
posted on 1/9/07 at 04:06 PM Reply With Quote
Dunning Fairbank in leeds will make you a prop for not much more than mk charge, much safer imho as there properly balanced
James
zxrlocost
posted on 1/9/07 at 04:32 PM Reply With Quote
any manafacturer should tell you what exactly you need when you purchase your kit
why wont your prop fit?
posted on 1/9/07 at 04:39 PM Reply With Quote
prop will be a rubber ring one rather than uj one. Just get a new one, they need balancing IMHO.
j30fos
posted on 1/9/07 at 05:41 PM Reply With Quote
for my MK I got bailey morris to make it, very very happy with it.
James
posted on 1/9/07 at 06:12 PM Reply With Quote
I'd agree, you'd be doing yourself a disservice not getting a proper balanced one made. They're only £100-120 new.
HTH,
James
Adam
posted on 1/9/07 at 06:27 PM Reply With Quote
I've emailed MNR about the prop.... any idea what their prices are, their web site doesn't say. My MK is having an R1 in it...BEC.
Any ideas on the UJ link, i've phoned a few motor suppliers and they say i need to find a breakers or try ford. Any one know where i might get one.
Cheers for all the help.
Adam
PS... Met a lovely chap at MK today, didn't catch his name. He drove a yellow MK and was and old chap.... VEry nice and helpful, learnt alot from him, just wanted to say thanks.
posted on 1/9/07 at 06:44 PM Reply With Quote
If he was wearing shorts it was our old man, Keith......
Phil
If I were you I'd go for a TRT propshaft from either of the companies mentioned (Dunning & Fairbank or Bailey Morris)
[Edited on 1-9-07 by Hellfire]
chrisg
posted on 1/9/07 at 06:56 PM Reply With Quote
Keith wearing shorts?
Never!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
afj
posted on 1/9/07 at 07:41 PM Reply With Quote
so does that mean my prop shaft is wrong UJ at diff end. UJ in middle. rubber at gearbox end thanks alan
Adam
posted on 1/9/07 at 09:48 PM Reply With Quote
Yep... thats the fella say thanks for me.
gttman
posted on 1/9/07 at 10:14 PM Reply With Quote
I'm planning to replace my R1 indy prop with a brand new one (going for all new reg).....
where is the best place to get one from and anyone one want the old one (its already modded by MK and been driven)?
[Edited on 1/9/07 by gttman]
Andygtt
Please redefine your limits
matt.c
posted on 2/9/07 at 08:29 AM Reply With Quote
Got mine modded at BAILEY MORRIS PROPS. Had the TRT fitted, ballanced and painted and had them check over the prop to check all the joints. All done and returned to me in 5 working days!
Def worth getting a new one just for the piece of mind.
[Edited on 2/9/07 by matt.c]
posted on 2/9/07 at 08:46 AM Reply With Quote
Dunning & Fairbank in Leeds will also custom build a propshaft to order, or modify your existing one, including rebalancing and painting. Great service.
Phil
chubby
posted on 3/9/07 at 11:59 AM Reply With Quote
Wilson Drive shafts made mine and did a great job!
they are based in Blenheim ind est. Bulwell Nottingham, so fairly close to you!
0115 976 1202
Hope that helps
Chubby
j30fos
posted on 3/9/07 at 09:18 PM Reply With Quote
eeeeeee memories very well made and the TRT makes it a bit less snappy ;-)
DarrenW
posted on 4/9/07 at 11:31 AM Reply With Quote
IMS in Birmingham made my prop. Top job, highly recommended.
macdave69
posted on 4/9/07 at 11:54 AM Reply With Quote
Phil
Yes shorts and racing boots, 6 months ahead of the latest fashion trend
BTW we got our propshaft from Wilsons in nottingham. 2 day turn round and an excellent job done too
[Edited on 4/9/07 by macdave69]
Avoneer
posted on 4/9/07 at 06:41 PM Reply With Quote
Phil
Apart from one of my weights coming off at Elvington and shaking itself loose at the engine end!
I've emailed them, but not yet had a responce.
Pat...
Adam
posted on 24/9/07 at 04:07 PM Reply With Quote
It Gets even Worse!
Just went to fit the diff.... and yes i have a 7.5" one..... just great! tried ringing MK but got no answer, from reading on here i'm pretty stuffed. Basically it means my donor car was a total waste of time and money, I thought these things were straight forward to build and enjoyable.... none of this has been the case so far
martyn_16v
posted on 24/9/07 at 04:32 PM Reply With Quote
I had that exact same problem, totally forgot to check the diff until i'd come to fit it. I used it as an excuse to buy an lsd instead, and then managed to get almost as much money for the 7.5" diff as I paid for the lsd, so at the end of the day it was all froody
welderman
posted on 24/9/07 at 05:40 PM Reply With Quote
my mates got a 7.5 diff in his indy, we re-fabricated the brackets that you bolt the diff to, from memory you only need to cut and weld one side as the body is just bigger one way or tother.
So dont go looking for one, get cutting and welding, job done.
Thank's, Joe
I don't stalk people
Gezza
posted on 24/9/07 at 07:17 PM Reply With Quote
IHi all, i got mine from MK, took six weeks to arrive, dont now if its balanced or not! Do they not balance after modifying as a matter of course??
New Topic New Reply
