paulmw
| posted on 9/9/07 at 01:45 PM |
Front wing brackets
I noticed on the forum that many of you struggled with the front wing brackets. As I am about to put them on is this correct
1) Bolt them in and then bend to fit
2) Remove, drill 2 holes and paint
3) Pop rivet into place
Have I got the right end of the stick as I can see them being launched into the garden very soon
paulmw
| posted on 9/9/07 at 01:53 PM |
Will Sikaflex be enough? Also if my bending is poo I might not be able to get much contact in the joint
| posted on 9/9/07 at 01:56 PM |
Sikaflex (or similar PU adhesive) will hold your wings on easily without problem.
Phil
fesycresy
It'll be enough
Just put plenty on.
cerbera
| posted on 9/9/07 at 02:42 PM |
I used PU adhesive on the advice of these guys and it works a treat. Like the proverbial sh*t to a blanket.
Oh, and looks neater too.
[Edited on 9/9/07 by cerbera]
iscmatt
| posted on 9/9/07 at 09:41 PM |
I used PU but as an extra i drilled around 5 holes along the top of the bracket to give the PU a little more to grip onto.
i was givin this advice by somebody on here a while back.
Hope this makes sense!!
paulmw
| posted on 10/9/07 at 07:32 AM |
Sikaflex it is. Also I am struggling to get the bracket to line up in the centre of the hub and ideas
