New Topic New Reply
Author: Subject: Clutch pedal
midge
posted on 10/9/07 at 12:19 PM Reply With Quote
Clutch pedal
I plan to fit a return spring to the clutch pedal (pedal to bulkhead) to retain the pedal position. This will mean the release bearing is up against the clutch. I can't see any other way of retaining the pedal. I'm using a HD clutch with extended fingers and standard release bearing rather than an extended bearing. Any thoughts / suggestions?
indykid
posted on 10/9/07 at 12:26 PM Reply With Quote
bend a bit of steel to 90degrees and drill an 8mm hole in one side. bolt it together with the pedal pivot bolt and your pedal sits wherever you've set the stop to.
i think the idea originally came from snoopy.
hth
posted on 10/9/07 at 12:29 PM Reply With Quote
Fit an aluminium stop to the bottom of the pedal. The pedal bracket will stop it falling forwards. Like this picture.......
You can also use it to attach the cable.
Phil
[Edited on 10-9-07 by Hellfire]
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 10/9/07 at 03:15 PM Reply With Quote
This is what i did, works a treat and allows for adjustment!
hth
tom
3GEComponents
posted on 10/9/07 at 03:21 PM Reply With Quote
hth
tom
Also as used on the new Haynes Roadster book
midge
Thanks for that guys, easy when you think about it.
paulmw
posted on 10/9/07 at 03:24 PM Reply With Quote
Thats wot i did. You could also bend it into a U shape and bolt on each side so that you dont have a sharp edge
Paul
New Topic New Reply
