paulmw
| posted on 21/9/07 at 01:48 PM |
New dash
Stupid question. Ive got the new MK dash. How do you fix it? Also, I pressume I need to chop out a bit for the steering column.
I can see a bodge coming on and want to make sure it eventually lines up with the other panels
Forgot to add how are the bike clocks fixed?
[Edited on 21/9/07 by paulmw]
worX
| posted on 21/9/07 at 02:00 PM |
Probably just as easy to cast your eye over these mate!
http://locostbuilders.co.uk/viewthread.php?tid=64223
PAUL FISHER
| posted on 21/9/07 at 03:53 PM |
On mine I used 7 rivnuts in the scuttle,and 7 4mm stainless button headed bolts.If your using the zx10r clocks,as I have,I split the clocks in two,cut
a suitable hole in the dash,then refitted them either side of the dash,so that the bulky bit of the clocks are at the rear of the dash.
