Colnago_Man
| posted on 2/11/07 at 08:25 AM |
Done a MK drum to disc convertion lately?
If so, do you have the small copper brake pipe that attaches the drum brake to the flexi going spare?
Beer tokens waiting.
Sadly found out last night that you can bend copper pipe easily by hand once, but come back a month later and try and bend it a bit more then it might
just snap in your hand!
afj
| posted on 2/11/07 at 09:26 AM |
like these
afj
| posted on 2/11/07 at 09:28 AM |
but as you can see the top one has the fitting on the wrong way round so you will need to re flare the end ( mk for you)
Colnago_Man
| posted on 2/11/07 at 09:32 AM |
There the ones!
I think its is the top one, bummer about the fitting being the wrong way round.
Could always just send it back to MK in the hope they will fix and return at no cost.
Cheer.
afj
| posted on 2/11/07 at 09:36 AM |
i dont need em you can have em both they are different in lenth by only 6-8mm ...no charge
martyn_16v
| posted on 2/11/07 at 10:08 AM |
I've got a pair i've no use for, PM me your address and i'll bung them in the post
