Jonte
posted on 22/11/07 at 07:15 PM |
MK radiator pics
Anyone here got good detailed pics of mounted radiator from MK?
Click it
macspeedy
posted on 22/11/07 at 07:20 PM |
tags
capri rad
Jonte
posted on 23/11/07 at 07:16 AM |
thanks
more pics please. trying to figure out how to use the z-formed alu thingys that comes with the rad
Click it
indykid
posted on 23/11/07 at 09:01 AM |
set your rad centred with the brackets bolted to the radiator, so that the square side of the brackets is towards the radiator. offer up the radiator
to the car and from memory, the top of the aluminium sections wants to be either 55 or 75mm above the top chassis rail. a trial with some clamps will
telll you which. if in doubt, ring MK as this was phil's advice.
mark up for rivnuts, set your rivnuts and bolt the brackets to the car.
tom
