Pezza
| posted on 12/12/07 at 04:57 PM |
Exhaust fouls brace
Got my engine in today.
Alas when i tried to fit the manifold it fouled the round tube diagonal
Now I don't want to cut out the cradle and it's associated brace.
Can this diagonal be removed without weakening the chassis too much?
Do the bike engined chassis have this brace? Or have I spaced the cradle wrong?
Ben
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
ditchlewis
| posted on 12/12/07 at 05:04 PM |
i used the mk manifold which exits over the top rail. expensive i know but it looks ok.
ditch
Opps ignore this you are using a different engine, getting late in the day and its been a hard day
[Edited on 12/12/07 by ditchlewis]
matt_claydon
| posted on 12/12/07 at 05:07 PM |
If you can weld, replace the single diagonal with two in a 'V' shape. Don't just remove it, I'd say it's pretty
fundamental to preventing the engine bay folding in half!
[Edited on 12/12/07 by matt_claydon]
jacko
| posted on 12/12/07 at 05:14 PM |
Cut the round tube at the front / top bend it down and re-weld to miss the manifold have a look in roadrunners photo archives i did his + tim
windmills cars on here
Jacko
Pezza
| posted on 12/12/07 at 05:17 PM |
Cheers chaps
martyn_16v
| posted on 12/12/07 at 05:44 PM |
I had the same problem when I trial fitted my exhaust manifold, it goes on but it's touching that tube. I was thinking along the lines of trying
to lean my engine over to one side a bit, or failing that 'relieve' the exhaust a little with the no1 tool...
mark chandler
| posted on 12/12/07 at 06:43 PM |
A bent tube is a pre-crashed one as they say.
You need to cut it out, then make up a Y brace as above, you will then have plenty of room and not weakened the chassis.
Takes 1/2 hour when you are this stage of the build.
Regards Mark
