badding
| posted on 28/12/07 at 11:17 AM |
rear fog light
I want to place the rear fog light in the middle on the back, is this allowed concerning the SVA and are there any requirements in the size and how
much light it produces?.
LBMEFM
| posted on 28/12/07 at 11:27 AM |
Yes it is OK to place it in the middle, it must be a designed for the purpose and the lens must be "E" marked and must be visable from 25
degrees of either side. Have a look on Car Builder Solutions or SVC Staffordshire web sites for pupose built lamps, they are quite cheap
| posted on 28/12/07 at 12:07 PM |
You will also need to make sure the fog light is vertical (ie you can't just attach it to the back of the car unless you use a spacer block).
There's a picture of my fog light in my photo archive (as it passed SVA).
| posted on 28/12/07 at 12:20 PM |
Here's ours. Passed SVA no problem
Phil
And close-up
badding
| posted on 28/12/07 at 03:58 PM |
This is what I made of it...is it oke like that or does it need some adjustments...
badding
| posted on 28/12/07 at 03:59 PM |
another pic
gingerprince
| posted on 28/12/07 at 04:00 PM |
Can't tell, the photo's not big enough
But looking at the second photo it looks like it's flush with the rear panel and therefore points upwards slightly? If so it needs to be
mounted on a backer, like the photo of Hellfire's.
[Edited on 28/12/07 by gingerprince]
