mad-butcher
| posted on 7/1/08 at 07:16 PM |
Fitting Wheel Arches to side Panels
This is the way i fitted mine, makes it easy to remove if you,ve bonded the side panels on
mad-butcher
| posted on 7/1/08 at 07:18 PM |
From inside
onzarob
| posted on 7/1/08 at 10:54 PM |
Very neat work and a top tip
RobH
| posted on 10/1/08 at 10:02 PM |
Good idea
mad-butcher
| posted on 10/1/08 at 10:36 PM |
The way i did it was to loosely fit the side panel, fit the rear wheel arches then remove the arches and side panels, the plates are made of 25mm x 3
or 4 mm bar about 50mm long drill and tap one hole the size of the bolt you're using to fix arch drill another hole in the flat bar , bolt the
flat bar to the inside of the side panel then drill through the fibreglass and fix plate with pop rivet I used 4.6mm large flange pop rivets, doing it
this way has 2 advantages 1) you can remove the wheel arch if needed 2) it spreads the load on the fibreglass
Tony
h8wyn
| posted on 27/1/08 at 07:38 PM |
Good job, looks really neat.
