mike smith1
| posted on 10/2/08 at 05:45 PM |
MK Fuel Tank & Sender Position!
As above, thinking about installing a fuel gauge so need to know the position of the sender in the MK Tank to avoid the internal baffle etc.
Need the Dimensions marked A & B, Obviously the centre of the sender would be helpful as shown.
Any one installed one as an "after thought"?? Pics of how it has been done would be good, can i get away with out using a split ring etc?
Cheers Mike
dan__wright
| posted on 10/2/08 at 05:58 PM |
where youve chosen is pretty much excatly where the baffle is (atleast thats where mine was for my in tank pump tank.
i put mine close to the filler.
FREE THE ROADSTER ONE…!!
mackei23b
| posted on 11/2/08 at 09:17 AM |
yes, that's where my baffle is as well. My sender is exactly in the middle of the tank.
Ian
mike smith1
| posted on 11/2/08 at 03:17 PM |
the middle it is then!! Will the fitting kit that comes with the sender be enough to seal etc as the tank has not been specifical made to take a
sender?
Mike
mackei23b
| posted on 12/2/08 at 09:56 AM |
Yes it should be fine.
Ian
sender?
Mike
asn163
| posted on 12/2/08 at 12:54 PM |
Hi Mike,
Keep us posted on how you get on with this, I really should fit one to ours.
Simon
mike smith1
| posted on 12/2/08 at 04:44 PM |
quote: Originally posted by asn163
Hi Mike,
Simon
I have an idea, you do it first and if it goes ok i'll do it after!!
Blackwater
| posted on 12/2/08 at 10:22 PM |
my baffle is in the center of the tank, so I put my sender like your pic
A dimension is about 10cm
[Edited on 12/2/08 by Blackwater]
Hope you can read and understand my english
mackei23b
| posted on 14/2/08 at 11:18 AM |
Hi there
Where my baffle was mounted, you cuold see a couple of deformations on the exterior of the tank where it had been welded internally. May be worth a
look just to double check where your baffle is.
Ian
