badding
posted on 11/2/08 at 12:11 PM |
some piccies in the sun
The car is almost ready, just some minor things before SVA.Made the vroem vroem noise on the driveway and drove the car a couple of times from the
start of my driveway to the garagedoor.
badding
| posted on 11/2/08 at 12:13 PM |
from the side
badding
from the side
[Edited on 11/2/08 by badding]
badding
from the back
badding
| posted on 11/2/08 at 12:16 PM |
inside
Howlor
Very nice job indeed.
| posted on 11/2/08 at 12:21 PM |
looks great
shame you have to leave the Sierra wheel fitted for SVA
twybrow
| posted on 11/2/08 at 12:36 PM |
Looks lovely!
ditchlewis
| posted on 11/2/08 at 01:01 PM |
looks real good
ditch
Omni
| posted on 11/2/08 at 02:10 PM |
LOOKS GREAT!
I have spotted one problem though.............................
.......................... the steering wheel is on the wrong side
(Only kidding!) Nice build indeed!
O
dr-fastlane
| posted on 11/2/08 at 04:51 PM |
Nice, I like the black color. And it's fine to see another Seven with the steering wheel at the right side, at the right side of europe
Where did get the front blinkers?
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
James
| posted on 11/2/08 at 05:08 PM |
Looks good.
Can you get full-lock with those headlights?
Only ask as I bought the same set hoping to do the same thing and couldn't get them to fit!
James
- Muhammad Ali
indykid
| posted on 11/2/08 at 05:25 PM |
quote: Originally posted by dr-fastlane
And it's fine to see another Seven with the steering wheel at the right side.........
nope, i think you'll find the steering wheel's on the left
tom
badding
| posted on 11/2/08 at 06:13 PM |
The front blinkers are bike ones, I made a Alu pipe to fit them on, because for SVA they need to be 400 mm max from the outside from the front wheels.
badding
| posted on 11/2/08 at 06:15 PM |
No, for SVA MK will put ordinary SVA approved lights, I will make a Alu disc on the lathe, with excentrix holes, so I can mound them a little
backwards or maybe under 45 degrees...
quote: Originally posted by James
Looks good.
James
