vinnievector
| posted on 3/3/08 at 01:23 PM |
hi guys
Hi ,looking to fit seat belts soon to my Mk some advise as to good harness and the bolt size for mounting . have the narrow body chassis not shore of
the age but would guess around 7 yrs ,and for the sva do i need to have a chassis num and if so where can i obtain this as i have no record of the age
or when manufactured by Mk hope you can help Vinnie .
Mr Whippy
| posted on 3/3/08 at 01:35 PM |
Europa specialist spares have good Westfield type harnesses, and you can order over the web.
Speak to MK, they will probably still have your order details and could give you a backdated reciept
vinnievector
| posted on 3/3/08 at 01:49 PM |
trouble
trouble is that this chassis has already had two owners before me ,and was in a poor state when i acquired it iam guessing at the age as i have owned
it now for 18 mths 2 yrs and i think the guy before me about the same the other i don't know but looking at the amount of corrosion that
managed to eat is way through the paint then at least a couple of years or longer .
Mr Whippy
| posted on 3/3/08 at 01:57 PM |
How about taking some pictures of it and then e-mailing them to MK. Their chassis was quite distinctive and evolved steadily so they may be able to
pin down a date of manufacture. Best thing would be to call them up and see if they could help you out, their nice guys.
James
You apply for a number or make one up (it's your choice) via DVLA.
My car took me 4 years to build, but I certainly didn't give DVLA a build date of 4 years previously.... I said about 6mths before I applied.
It's not as if they're gonna carbon date your chassis!
HTH,
James
- Muhammad Ali
matt_claydon
| posted on 3/3/08 at 02:01 PM |
MK don't issue chassis numbers, and the age is not relevant for anything. You can either make up your own or have one issues by you local DVLA
office. DIfferent offices work differently so I suggest you get in touch with the one you will be registering the car with and take their advice.
Regarding the belts, MK added reinforcement to the later Indy mountings and without these reinforcements the mountings will likely fail the SVA. I
imagine the early MK non-Indy chassis uses the same non-reinforced mounts.
Mr Whippy
| posted on 3/3/08 at 03:23 PM |
no I thinking more of a proof of purchase reciept from MK rather than anything to do with chassis number
vinnievector
| posted on 3/3/08 at 06:00 PM |
Re chassis
Think that clears up the chassis part ,
as for the harness mounting points they are made i think from solid round bar about 20mm dia drilled and taped out to i don't know wot size.
hoping you guys could help might be unf .
some moor advise on harnesses makes and deals .
jacko
| posted on 3/3/08 at 07:59 PM |
The mounts for the seat belts are 7/16 unf
your chassis i think will be about 5 years old because it has the type of diff mounting that first was fitted about 5 years ago u2u snoopy on here he
will know
If i was to buy seat belts again i would not buy sabelts i find they keep coming loose
Graham
[Edited on 3/3/08 by jacko]
vinnievector
posted on 4/3/08 at 07:14 AM |
Thanks for the advice .
