New Topic New Reply
Author: Subject: wiring loom
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 3/11/03 at 02:34 PM Reply With Quote
wiring loom
Anyone suggest a wiring loom i can purchase that gives connectors for steering column switches and fireblade engine connectors? Martin at MKs loom is a wee bit pricey at £150 odd
greggors84
posted on 3/11/03 at 02:41 PM Reply With Quote
I bought mine from premier wiring, it was £100 and thats for the sierra one. Not sure of their number, but if u give them a call, they may do one for a bike engine.
Chris
The Magnificent 7!
bob
posted on 3/11/03 at 07:51 PM Reply With Quote
http://www.premierwiring.co.uk
0800 0742789
not sure if the freephone is still in use but worth a try,really nice people to do business with and a great product.
[Edited on 3/11/03 by bob]
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
posted on 4/11/03 at 12:30 AM Reply With Quote
Excellent. thanks guys shall give 'em a call!
MK7
posted on 4/11/03 at 08:55 AM Reply With Quote
Switch burnout
I think any of the looms can use the column switches, however, the problem is that the switches won't last. I had this discussion with the manufacturers of the MK loom.
With all the lights on (Main beam, headlamp and side / tail lights) the headlamp switch is carrying about 30 Amps.
Ideally you need to fit additional relays. I've posted drawings about how to do this.
As an aside, untli MES re-design the MK loom with adequate input from MK, I wouldn't buy one.
Russell
bob
posted on 4/11/03 at 09:03 AM Reply With Quote
The premier wiring loom already has the relay sockets wired up for dip and main plus indicators and wipers if needed,its just a matter of fitting a few wires to determine wether your switches are 83BG or 87BG wiring.
All the info supplied with the wiring kit was very easy to follow and the fuse box is already wired too which was a great help,even some convoluted tube and a load of tie wraps and a crimping tool are included among other bits.
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
posted on 4/11/03 at 09:21 AM Reply With Quote
i'll give premier a call, and i'll check there are the appropriate bits for relay control. thanks again guys
New Topic New Reply
