afj
| posted on 11/3/08 at 06:38 PM |
mk tank question
can anyone tell my why i seem to have 2 breathers at the top corner of my mk tank. r1 injection pump in the bottom has feed and return. both are
drilled thru into tank?
fesycresy
| posted on 11/3/08 at 06:53 PM |
Some pumps don't have a return (Fireblade 1000RR) and would need one into the the tank.
The second would be used for a tank vent and connected to a Mocal type breather / tip over valve or alternatively just a doubled over pipe to vent.
HTH.
nitram38
| posted on 11/3/08 at 06:55 PM |
Better speak to MK, but are you talking about injection or carbs?
If injection the pump will have it's own outlet so the two pipes will be a return and a breather or if an internal pump is used for carbs, one
could be the pump outlet and the other a breather.
Normally carbs don't need returns.
[Edited on 11/3/2008 by nitram38]
afj
| posted on 11/3/08 at 07:02 PM |
injection pump, has 2 1 feed to engine and 1 return from engine. but i dont need the 2 at the top do i? 1 for a breather whats the other for
Jay k
| posted on 11/3/08 at 08:46 PM |
It looks to me as you have been supplied a tank that has a pipe for the return to go to, as you do not need I would say you have the wrong tank. In
theory you could just blank one of the pipes off.
Speak to MK, IMHO
