eddbaz
| posted on 12/3/08 at 07:29 PM |
indy pedals
My clutch and throttle peddals have different size holes where the cables will connnect to the clutch is around 5-6mm diameter where the throttle is
2-3mm diameter is this correct.
indykid
| posted on 12/3/08 at 08:32 PM |
i've got M6 bolts in both my pedals.
i had to drill one of mine bigger so i guess it was the accelerator.
tom
tim windmill
| posted on 13/3/08 at 01:32 PM |
thats normal, just redrill if required. all depends on how you are fixing your cable to the pedal, i have drilled mine for m6 bolt
