Blackwater
posted on 17/3/08 at 07:06 PM |
Pedal to throttle wire?
I canīt understand how to get my throttlewire on to my pedal. Itīs just a small drilled hole and my wire is blank at that end.
easy description or good pictures are a big help
Hope you can read and understand my english
| posted on 17/3/08 at 07:26 PM |
heres mine....
rotax78
| posted on 17/3/08 at 07:29 PM |
this is how i've done mine, the bolt that goes through the pedal is loose so that it can turn as the pedal moves
  pedals/cables
[Edited on 17/3/08 by rotax78]
stuart_g
| posted on 17/3/08 at 07:57 PM |
Here's how I did mine.
| posted on 17/3/08 at 08:00 PM |
I got one of those chocolate-block type wire connectors and use the inner metal bit- two screws to clamp on to the wire..
Use one either side of the pedal bar...
Blackwater
| posted on 18/3/08 at 06:46 PM |
Thanks for the replyes. Strange that only 1 indy builder answers . Has no one else solved this.
Is that safe, doesnīt get loose after a while?
Rotax78
I donīt have that thing at the end of the wire, itīs just a loose wire.
Iīll try to solve this somehow
lococost
| posted on 18/3/08 at 07:19 PM |
Ha, finally a fellow Belgian indy builder!
I ordered some cheap clips from rallydesign and modded them a bit.
More info and pics on the www below.
If you bought the kit from Haselier, chances are he's got some that don't need modding.
Dunno where you are exactly, but feel free to come and have a look.
kastrato
| posted on 18/3/08 at 07:46 PM |
mine is the same with rotax78 's
[Edited on 18/3/08 by kastrato]
MK INDY fireblade
