New Topic New Reply
Author: Subject: Clutch pedal stop?
Bluemoon
posted on 18/3/08 at 10:20 PM Reply With Quote
Clutch pedal stop?
Hi all.
Do I need a clutch pedal stop on a CEC? It's a bit of a pain to fit one, as the footwell pannel is curved so the old nut and bolt stop will not work, and I the a bracket on the floor will just flex and probably bend the floor pannel..
Is it realy required as the cable is quite thick, or will the cable eventualy snap??
Dan
indykid
posted on 19/3/08 at 07:01 AM Reply With Quote
my clutch pedal hits the bulkhead long before it's run out of travel.
no stop required imo.
tom
flak monkey
posted on 19/3/08 at 07:43 AM Reply With Quote
Ditto tom.
My pedal hits the bulkhead, but the clutch is disengaged about halfway down. A stop would probably speed up gear changes, but I cant be bothered too fit one at the moment!
Sera
http://www.motosera.com
Mr Whippy
posted on 19/3/08 at 08:23 AM Reply With Quote
I don't recall even production cars having one, usually limited by the clutch travel itself. In general it’s only the throttle that needs a stop to protect the carbs.
Bluemoon
posted on 19/3/08 at 09:12 AM Reply With Quote
Cool will only stick on on the accelerator then, problem solved!
Dan
vinnievector
posted on 21/3/08 at 10:23 AM Reply With Quote
hi
Mine to just hits the footwell just stuck some thick rubber to the footwell .
Vinnie.
New Topic New Reply
