eddbaz
| posted on 19/3/08 at 07:00 PM |
willwood rear calipers
Anyone fitted rear willwoods to sierra rear drive,I was told that I neededed 273mm rearr disc,got the brakes and adaptors from rally resign,when
fitting the rears using adaptor provided (bk 67 stamped on it) the caliper doesn,t seam to be far enough into the disc,there is about 10mm of the top
of the brake pads showing,the fronts I fitted seam perfect.Any ideas?
P.S whats the best way of posting photos,do they need scaling and what is the easiest way to do it. Cheers
eznfrank
| posted on 19/3/08 at 07:34 PM |
I had a very similar problem (in fact both problems) a few days ago. Although not Wilwoods I had Coswroth calipers that wouldn't sit far enough
forward on the disc. After alot of messing around with Halfrauds computer I managed to figure out they had given me discs for a later year car which
have a shallower collar (not sure if that's the best way to desribe it) whereas the new ones I now have sit about 8mm further back into the
centre of the caliper and slider.
Photos - yeah I aint got a clue either!!
P.S. did you manage to get a chance to dig out those photos of the ZX12 mountings??
CHeers mate
eddbaz
| posted on 19/3/08 at 10:06 PM |
if you u2u me your email adress i'll send them photos direct to you.
RazMan
| posted on 20/3/08 at 05:29 AM |
Not much of a picture but this is my setup - Powerlites and XR4 (I think) discs
[Edited on 20-3-08 by RazMan]
Raz
RazMan
| posted on 20/3/08 at 05:41 AM |
Compared to the old Sierra setup
Raz
eddbaz
| posted on 20/3/08 at 12:58 PM |
hope this picture comes out
| posted on 20/3/08 at 05:27 PM |
No picture there Ed. The picture needs to be either online or uploaded into your Locostbuilders photo archive before it can be displayed.
Phil
[Edited on 20-3-08 by Hellfire]
eddbaz
| posted on 24/3/08 at 05:31 PM |
whats the easiest way of scaling a photo so its the correct size when uploaded.
RazMan
| posted on 24/3/08 at 07:30 PM |
A few options here
Raz
ragindave
| posted on 24/3/08 at 07:43 PM |
eddies problem with pictures
These pictures are of eddies brake problem pads do not cover the disc.
Is it the disc size?
Or is it the adaptor bracket?
Or could it be both?
