eznfrank
| posted on 27/3/08 at 10:51 PM |
removing sierra driveshaft abs teeth
to fit the rear driveshafts from a xr4x4 sierra to rear disc uprights on an indy i need to grind off the teeth on the abs bit on the end? Does that
round right? Could explain why hub carrier won't go on properly. How's best to do it? Angry grinder?
PAUL FISHER
| posted on 27/3/08 at 10:57 PM |
Best way to remove the teeth is on a lathe.
Mr Whippy
| posted on 27/3/08 at 11:05 PM |
I used the angle grinder and a flapper wheel, what the hell you can't see it anyway...
here's how much I removed, quite a lot really and it only just fitted
blakep82
| posted on 27/3/08 at 11:45 PM |
is it possbile to unbalance it if its not done on a lathe?
________________________
smart51
| posted on 28/3/08 at 07:55 AM |
I did mine with an angle grinder. so long as it is even all round, it won't be out of balance. I did mine so that all the grooves between the
teeth were almost but not quite flush. Assuming all the grooves were of equal depth to start off with, the thing will be round when you've
done.
Mr Whippy
| posted on 28/3/08 at 10:27 AM |
how fast do wheels turn? about 100rpm at 70mph? plus the metal removed is only about 5cm from the centerline
Hammerhead
| posted on 28/3/08 at 10:46 AM |
got a local machione shop to turn mine down on the lathe think it was £10 cash for the pair.
Is that locost?
Mr Whippy
| posted on 28/3/08 at 12:56 PM |
Is that locost?
you have £240 left
James
| posted on 28/3/08 at 01:56 PM |
I didn't want to risk unbalancing it (assuming Henry Ford balanced them in the first place!!! ).
So I removed metal from the upright instead. Didn't take long with a good half-round file.
HTH,
James
- Muhammad Ali
martyn_16v
| posted on 29/3/08 at 10:17 PM |
Mine fitted fine in the new uprights. Not that that's any help at all if you have the old
