New Topic New Reply
Author: Subject: MK Indy - Self Centering
mackei23b
posted on 30/3/08 at 06:53 PM Reply With Quote
Just going through the final SVA prep before booking the test and I set up the front suspension.
I used 1 degree -ve camber, 1 degree tow out and about 15PSI in the front tyres and got some decent self centering, no need for valve springs in the rack.
Hope this helps others.
Ian
Stuart_B
posted on 30/3/08 at 06:57 PM Reply With Quote
if that works i will do that on my indy when it comes to sva time.
stuart
nitram38
posted on 30/3/08 at 07:18 PM Reply With Quote
After 40+ years of the 7, why aren't manufacturers putting castor in their wishbones?
If they did, all this talk of self centering would be history!
roadrunner
posted on 30/3/08 at 07:25 PM Reply With Quote
Mine hardly self centered pre SVA , but it still passed.
mangogrooveworkshop
posted on 30/3/08 at 07:28 PM Reply With Quote
10 out of ten with that statement
I have this problem at the moment but a remake of the top bone will cure that.
The other thing is to make sure your steering colum is not binding and it spins freely as well as grease in the rack being dry from standing around for a few years.
Stuart_B
posted on 30/3/08 at 07:36 PM Reply With Quote
then what would we all talk about?
stuart
nitram38
posted on 30/3/08 at 08:26 PM Reply With Quote
stuart
Or have un-necessary work to do?
JohnN
posted on 31/3/08 at 07:33 AM Reply With Quote
IIRC Luego (Grant, Matt et al) wishbones did/do build in castor, they are "handed"
New Topic New Reply
