New Topic New Reply
Author: Subject: indy with vaux c20x - value?
Flick
posted on 2/4/08 at 05:33 PM Reply With Quote
hi
just needed a bit of advice. Was originally after a bec but ive just been offered a indy fitted with c20x and omega gearbox. Cluth is gone and the guy thinks the flywheel will need changing. registered 2006 in rizla blue. And Any idea on rough value? Anyone know this car..
Also what are these engines like?
tjoh84
posted on 2/4/08 at 05:41 PM Reply With Quote
i thinke you will find that is the c20xe out of the old astra gte never had one but from what i heard they are better than the eco tec engine and was fast in that astra so should be fun in mk
MikeR
posted on 2/4/08 at 05:51 PM Reply With Quote
heavy but damned fast. standard engine with decent exhaust and induction should be 180+bhp.
Heavy = around pinto territory.
Speak to Ned or NSDev - both have them and both know a thing or two about them (NSDev raced one for a number of years)
AndyW
posted on 2/4/08 at 06:02 PM Reply With Quote
if its a 2.0xe then non cat if a C20XE then cat engine i.e fixed dizzy. Still a damn good lump, check head for signs of being pourous other than that a good engine
Flick
posted on 2/4/08 at 06:59 PM Reply With Quote
Thanks for the advice.
Think im going to give it a miss, was looking for a bit more power to weight.
The search continues.......
LBMEFM
Sprinted a GTE Astra for several years, the engine was absolutely brilliant, replaced the car with a MR2 (4age), the engine was crap and lasted just two meetings.
Would recommend the Vauxhall engine everytime. As for value, one in good nick, I would suggest, would be worth in the region of £6 to £7k but less with a worn clutch.
[Edited on 2/4/08 by LBMEFM]
New Topic New Reply
