New Topic New Reply
Author: Subject: INDY GEAR CHANGE RODS
matt.c
posted on 11/4/08 at 08:02 PM Reply With Quote
Hi locosters, Im having a bit of trouble at the moment with the sloppyness of my gear changing rods. I have the rod ends as close to the pivots but there is still to much movement for me.
I like the feel of the gearknob being very solid ie less movement for gear changing.
What about moving the rod from the bottom of the gear stick to the middle or as high as i can get to the gear knob. Will this minimalise the movement?
Gear
Gear
jacko
posted on 11/4/08 at 08:08 PM Reply With Quote
Road runner has some photos in his archives how he made his it may help you
Jacko
dan__wright
no that would make it further, move it further from the pivot, or change it the gaerbox engine put it closer to the selector.
FREE THE ROADSTER ONE…!!
mackei23b
posted on 11/4/08 at 08:16 PM Reply With Quote
Hi Matt
Here are your options for less movement at the gear lever:
Option 1 lengthen point A from pivot
Option 2 shorten point B from pivot
Option 3 lengthen point C from pivot
Option 4 shorten point D towards pivot
Ian
[Edited on 11/4/08 by mackei23b]
[Edited on 11/4/08 by mackei23b] Rescued attachment Gear Link.JPG
matt.c
posted on 11/4/08 at 08:33 PM Reply With Quote
Have made all the rods as close as possible to there pivots. If thats the case then would pic 2 have less movement at the gearknob than pic 1?
I could make the link fit higher on the gearknob.
[Edited on 11/4/08 by matt.c]
mackei23b
posted on 11/4/08 at 09:04 PM Reply With Quote
Yes it would.
gingerprince
posted on 13/4/08 at 05:53 PM Reply With Quote
If all your joints are as close to the pivots as possible, then the easiest way is probably to drill point C in mackei's diagram further out - that'll increase throw to the engine compared to throw in your hand achieving what you want. I wouldn't bother re-engineering the whole thing like you were suggesting.
New Topic New Reply
