graememk
| posted on 13/4/08 at 06:31 PM |
mk indy spanner size
what size spanner do i need for the nuts on the top wish bones, front and rear.
40mm springs to mind ?
COREdevelopments
| posted on 13/4/08 at 06:32 PM |
40mm!! thats huge!!
Paul (Notts)
| posted on 13/4/08 at 06:35 PM |
19mm at a guess
| posted on 13/4/08 at 06:36 PM |
If it's the one holding on the top wishbone with the 12mm thread through the poly-bushes - the size is 19mm AF.
DRC INDY 7
| posted on 13/4/08 at 07:12 PM |
19mm or3/4AF
Puddle Dodgers Club
Doofus
| posted on 13/4/08 at 07:58 PM |
It's not 22, just checked, but a bit bigger.
It's for the nut on the M18 transit drag link, yes?
graememk
| posted on 13/4/08 at 08:05 PM |
its the one at the back that comes undone, theres 3 on each side.
matt_claydon
| posted on 13/4/08 at 08:08 PM |
I think he probably means the ones to adjust the camber!
38mm rings a bell for the back, but I'm not sure. The front is much smaller, maybe 22-24mm?
procomp
| posted on 14/4/08 at 07:09 AM |
Hi the STD size nut/spanner for the 18MM transit thread is 27mm. However i seem to remember that the thread and adjuster on the back end are of a
larger size. Or is that one of the other manufacturers.
Cheers Matt
mike smith1
| posted on 14/4/08 at 03:22 PM |
Definatly 38 or 40mm i cant remember which, i'll confirm later as i'll be checking my nuts before i go out for a blast!
[Edited on 14/4/08 by mike smith1]
mike smith1
| posted on 15/4/08 at 10:02 AM |
I was wrong, it is 30mm
