afj
| posted on 17/4/08 at 05:31 PM |
lower shock mount
can you please have a look at the pic below of the near side lower shock mount is this amount of packing one side and not the other OK. its the same
on both sides
mookaloid
| posted on 17/4/08 at 05:34 PM |
I would say it's ok - the alternative id to bend the shocker which is not a good plan.
Mark
| posted on 17/4/08 at 09:14 PM |
Looks the same as mine
procomp
| posted on 18/4/08 at 06:58 AM |
Hi the damper should sit freely on it's bushes. It looks like you are still placing a strain on the the bushes/piston rod.
Also check that the outer end of the damper is not touching the bracket.
Cheers Matt
afj
| posted on 18/4/08 at 07:04 PM |
everything looks straight inclueding the damper..must be my dodgy camera work thanks for the input alan
procomp
| posted on 19/4/08 at 08:58 AM |
Hi the damper is clearly not sat freely. As you can see from the picture that the top of the damper needs to be brought back toward the left at the
top ( in the picture ) to place the damper at a right angle to the mounting bolt through the lower bush of the damper. There should be room on the
top bracket to alighn the damper by spacing it back to the left ( in the picture ) at the top.
HTH cheers Matt
afj
| posted on 19/4/08 at 02:59 PM |
in that pic above the top of the damper is not bolted to anything!
afj
| posted on 19/4/08 at 03:03 PM |
how does it look now?
