Stuart_B
| posted on 18/4/08 at 11:08 AM |
Pedal's
hi all, what end do you need for the throttle cable? or do you need to alter the pedal?
thanks
stuart
Bluemoon
| posted on 18/4/08 at 11:18 AM |
L bracket to pedal with bolt to allow movement. Hole for cable and smaller end of L. Nipple cut off cable, choc block connector used and washer to
stop cable moving though hole in L bracket.
The L bracket was made small enough to fit though "tubes" in bulkhead to ease latter cable replacement...
Dan
