kelloggs
posted on 27/4/08 at 12:56 PM |
dellorto 45 carbs for ford crossflow
I have the opportunity of acquireing a pair of dellorto 45 carbs they were originally fitted to a 2lt pinto previouse owner had great difficulty
getting them set up & running, after spending a lot of money cleaning and getting new jets had no success, the new jets fitted for the pinto
were;-
main 142
idle 60
air 177.5
emul 7772.7
pump 38
original jets were;-
main 160
idle 50
air 230
emul 7772.8
pump 42
as anyone had any success with running dellorto 45 on a 1600 crossflow. Also were can I obtain a inlet manifold for said item
StuartBJ
posted on 27/4/08 at 01:26 PM |
I once had twin 45 dellortos and went through the same thing, refurb/re-jetting etc......mystery.
Even though they are meat to be a little more powerful and an improvement over the webber design I would avoid future use unless they were brand
spanking new!
But thats just my experience!
wonderfulweasel
posted on 27/4/08 at 01:33 PM |
I think Burton Power do the manifolds brand new. They also appear second hand on Ebay fairly regularly.
Is your engine standard or modified? They may be a bit overkill on a standard 1600 crossflow.
posted on 27/4/08 at 02:56 PM |
Agreed, the 135bhp Caterham Supersprint managed on 40DCOEs, so going for 45's with a lower state of tune is only going to hurt driveability.
gazza285
posted on 27/4/08 at 05:15 PM |
All depends on what size venturi have been fitted, my old crossflow ran fine on 45s.
andybod
posted on 27/4/08 at 06:18 PM |
i have a pair of dellorto 45's on my crossflow allthough it is running 1600cc it's at quite a high state of tune for a crossflow
kelloggs
posted on 27/4/08 at 07:50 PM |
Thanks for all the replies, work carried out on engine was complete re-bore, head skimmed, lead free seats fitted, re-grind crank, new cam followers,
fast road camshaft, fly wheel faced and lightened. have not yet fitted electronic ignition. Any suggestions on what size jets for 1600 crossflow
tcr
posted on 27/4/08 at 07:57 PM |
hi ive just had the same problem with 45 dellorto's including 5 hours on rolling road ,save yourself alot of time and money try to go the bike
carb route if possdont know if this is any good for you
http://members.aol.com/dvandrews/dellorto.htm
[Edited on 27/4/08 by tcr]
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
posted on 27/4/08 at 08:00 PM |
I have a set of weber 40 DCOEs with a cross flow manifold that I'm not going to be using . Carbs would need an overhaul and rejetting , open to
offers
paulf
posted on 27/4/08 at 08:24 PM |
They look nice, but as already mentioned I would go for bike carbs or throttle bodys as setting them up is expensive and there never very
economical.
Paul.
