New Topic New Reply
Author: Subject: indicator stalk
indyian
posted on 29/4/08 at 04:27 PM Reply With Quote
indicator stalk
hi all i was wondering if anywon had any ideas wot i could use for indicator switch and main beam if i was to remove it all from sierra collum i have been thinking for days an just cant come up with anything please help its driving me mad ???????
bassett
posted on 29/4/08 at 05:09 PM Reply With Quote
How bout some switches for it all instead. Europaspares do the small round ally ones.
Adam
indyian
posted on 29/4/08 at 05:46 PM Reply With Quote
indicator stalks
will it pass sva with switches on dash???
bassett
posted on 29/4/08 at 06:24 PM Reply With Quote
It will if they are sva approved ones. The push button motorsport ones are fine as they have a tiny radius. If your worried put them in the area behind or around the sterring wheel of 127mm which is exempt from sva
[Edited on 29/4/08 by bassett]
indyian
posted on 29/4/08 at 09:16 PM Reply With Quote
thanks for the info
posted on 29/4/08 at 09:42 PM Reply With Quote
If it's just the fact that you don't like the look of the Sierra switches, you can modify them as I did.
If the stalk is sawn off just above the little flat bit inside the shroud you will find a small hole. You can glue a steel pin into there, then a nicer stalk onto that.
I did my new stalk on my lathe, but there used to be someone on ebay selling suitable items.
New Topic New Reply
