jonesier1
| posted on 8/5/08 at 06:53 PM |
new to megasquirt..... advise please.
hi, been looking at mega squirt engine management for fuel and ign ,can someone tell what i would need to run a silver top zetec 2.0 using the
standard flywheel and sensor and lambda.Ive seen them on ebay but dont really kknow what im buying.An exlanation in idiot form is required .cheers
Paul TigerB6
| posted on 8/5/08 at 07:04 PM |
Have you found the specific forums for megasquirt at all??
here's one
and another
this will help too
For a zetec you will probably want to look at a set of suitable motorbike throttle bodies from a 600cc+ bike, manifold to suit from the likes of Bogg
Bros, use the standard crank position sensor on the flywheel along with the standard coil pack. You will need to look at various sensors for air and
water temp etc but the info is all on the links so plenty of evening reading there for you
There are others with infinately more experience than me on here but personally from what i've read i'd be looking at fitting a wideband
lambda sensor in the exhaust,which can be configured to map the ECU so you dont need to get it on the rolling road for tuning. Have a look at the 3rd
link "FAQ" for info on this.
[Edited on 8/5/08 by Paul TigerB6]
piddy
I would say you need.
The mega squirt, wiring harness for the M S, Air temp sender , Water temp sender, EDIS unit, fuses relays time and patients.
Please add to the list if I’ve missed something.
Werner Van Loock
| posted on 8/5/08 at 07:09 PM |
If you don't know what you're doing, then take a look at extraefi.co.uk or
m-tech
And for overseas ($ benefit) diyautotune
Or like me, Agriv8 and Se7ensport
(And I'm building it on a 1.8 silvertop zetec using GSX-R throttle bodies)
VEMS
VEMSuk
http://www.clubstylus.be
clairetoo
| posted on 8/5/08 at 07:48 PM |
I`d avoid Mtech - I had a very bad experience dealing with them (12 week delivery , then sent it after I`d given up and canceled....)
They are not on the BG approved vendors list for very good reason .
Its cuz I is blond , innit
Claire xx
Will weld for food......
