New Topic New Reply
Author: Subject: Dampertech Offer
vintagebuilder
posted on 26/11/03 at 12:52 PM Reply With Quote
Dampertech Offer
Afternoon All,
I,ve been looking at the Dampertech offer of 4 dampers and springs for £250. In the MK build manual it says that the rear springs are rated at 200lb and the fronts are 350lb. Further on in the manual it says the fronts are 300lb.If I order from Dampertech which do I need?
Does anyone know of a retail outlet that sells silicone grease for the Poly bushes, can't find anyone local.
Regards
greggors84
posted on 26/11/03 at 04:28 PM Reply With Quote
We got 200 on the back and 350 on the front with the kit. It depends on what engine you have in the front as obviously a pinto weighs alot more than a bike engine. We have a pinto by the way.
Also we used Castrol CL grease, it is a chassis grease and im guess ok for the bushes. I hope so as they are firmly in the wishbones and on the car now! You can pick up 500g pots of it from Halfords.
Chris
The Magnificent 7!
mangogroove
posted on 26/11/03 at 06:05 PM Reply With Quote
which offer is this?
SPECIAL - IN STOCK NOW!
Spring & damper set to fit self build Locosts, factory build Locosts (all companies)
Comprising of:
4 x 2 1/4 I/D Zinc plated fully adjustable coil over dampers with 3 years warrenty
4x 2 1/4 I/D Zinc plated fully adjustable coil springs
ONLY £330 including VAT & CARRIAGE
or
4x1.9 I/D (17/8" Units with springs and 3 years warrenty
ONLY £300 including VAT & CARRIAGE
vintagebuilder
posted on 26/11/03 at 06:51 PM Reply With Quote
It's the offer in this months Which Kit mag.
"Attention Locost Builders"
4x1.9 Gaz adj coil over dampers plus 4x1.9 quality powder coated springs, inc carriage and VAT.
Mk-Ninja
posted on 26/11/03 at 07:01 PM Reply With Quote
As greggors say it must be too do with the engine you fit and thus the sprung weight. I got 200 for the back and 300 for the front using a ZX9R bike engine.
I'm sure I've got one, just don't know where I've put it
ainsml
posted on 27/11/03 at 03:34 PM Reply With Quote
if you give him a ring he will tell u what spring rates u need.
New Topic New Reply
