mad-butcher
| posted on 16/5/08 at 05:53 PM |
Maplin noise meter
Can't find the topic, but i know some-one else on here bought on, just curious as to how accurate they found it
tony
smart51
| posted on 16/5/08 at 06:13 PM |
I have one. It seems to read a couple of dB louder than that at Cadwell Park. It was usefull for seeing how much difference various mods made.
| posted on 16/5/08 at 06:21 PM |
From a point of view of checking silencer mods (ie is it any quieter now?) they're worthwhile but they're fairly cheap and properly
calibrated db meters cost £££££ IE if you turn up at SVA saying "but my db meter says" they'll quickly explain that it's
because your db meter has the accuracy of divining rod...
mad-butcher
| posted on 16/5/08 at 06:25 PM |
Thanks for that, had mine for about a year and it seems pretty accurate but just corious how you found yours,brother inlaw is sending a brand new LCR
racing outfit over to germany for one of the world championship rounds and we need to check exhaust, long way to send it only to fail on exhaust
tony
owelly
| posted on 16/5/08 at 07:19 PM |
TER Intruments can calibrate it for you but it may well cost more then the meter! You could always hire one for a few days. I think Livingstone Hire
do them. Or buy one from RS and send it back after you have used it........
http://www.ppcmag.co.uk
matt_claydon
| posted on 16/5/08 at 07:29 PM |
Bear in mind even with expensive calibrated meters, if you haven't also got an expensive calibrated location readings can vary 1 or maybe even 2
dB depending on the surface, objects in the surrounding area, wind, atmospheric conditions etc. So if you get it right on the limit here, the
scrutineers at the event may well get a higher reading - so allow a margin of safety!
bimbleuk
| posted on 17/5/08 at 05:10 AM |
If you can go to a test day or track day near you and ask nicely to get noise tested. I do this at Castle Combe and use my cheap gauge at home so
I've now got a rough idea how loud it is.
Agriv8
| posted on 17/5/08 at 08:42 AM |
mines 3 or 4 out when tested at beverly sva.
regards
agriv8
