marting
posted on 3/6/08 at 12:53 PM |
Leaking radiator
Hi Everyone
first of all thanks for the help on the expansion tank cap i have on now.
i have another problem, the is a leak coming from radiator i'm loosing water every now and then. i think its coming from the cap or the bleeding
nozzle next to it. i don't even know what car the radiator is from to replace bits. has anyone had this problem before, help
posted on 3/6/08 at 01:14 PM |
MK usually supply a modified mk2 Escort rad as part of their kits so there's a good chance that's what you have fitted (assuming you
bought a built car?).
A few pics will help identify the radiator for sure.
DaveFJ
posted on 3/6/08 at 01:16 PM |
Could you have fallen foul of the same trap I did?
I had a pressure cap on my expansion bottle and a pressure cap on my radiator. this seems to have led to air being sucked into the radiator leading to
airlocks and overheating - at whcich point it dumped coolant from the radiator - hence it was not happening constantly...
I solved it by pulling the radiator cap apart and sealing up the pressure relief mechanism with that 2 part loeak stop glue stuff. Had no problems
since (cross fingers~!)
Dave
posted on 3/6/08 at 01:29 PM |
as DaveFj points out, you have only one peressure relief cap; either on the radiator in whcih case there is a small tube that goes to a bottled vented
to air or else have one on the expansion tank.
why you say you are losing water, do you know where from? antifreeze will leave a cryslline deposit. or get some white hand towels and put around
warous parts of the colling system to trace the leak (obviously aeway from exhaust and hot spots).
don't discount the possiblity of the water could be leaving via the engine too
marting
posted on 3/6/08 at 01:32 PM |
Hi Dave thanks for the advice
i don't think i'm quite sure what you mean. are you saying the water is leaking out of the bleeding mechanism because the cap is not
sealing properly and sucking air in
DaveFJ
posted on 3/6/08 at 01:38 PM |
I beleive that the presure caps are designed to release pressure at a certain point but the design also allows air to be sucked into the system...
that was the explanation I was given anyway and teh advice seems to have paid off! I decided to keep the presurised cap on the expansion tank rather
than the Rad because it was higher up.
Dave
marting
posted on 3/6/08 at 02:07 PM |
I Have just had a thought when i did a trackday at the weekend the cap off the expansion tank blew off and had to replace it because i couldn't
find it i just thought i hadn't tightened it properly. do think it blew off under pressure and thats why i am getting the leaking. prssure
caused by air locks maybe
DaveFJ
posted on 3/6/08 at 02:12 PM |
cap should have vented long before enough pressure built up to blow it off....
Dave
marting
posted on 3/6/08 at 03:00 PM |
i think i'll go with the sealing up the radiator cap first ,cheers
posted on 3/6/08 at 04:38 PM |
yes and no.
radiator cap with overflow tank. the water will expand and push the cap open overflowing into the tank. when water cools, it sucks water back into
the radiator. you would normally fill the radiator up to the neck so there is virtually no air in the system.
expansion tank is different - and I may be wrong here - but there is ussually air in the tank. you fill the tank to some mark on the side of the tank
and as the water expands, the water level rises. air inside the tank is compressed and once it reaches a certain pressure, I guess the cap has to
vent. as the water cools air has to be drawn in or else the tank or hoses collapse due to negative pressure.
So one system draws in air and other does not.
DaveFJ
posted on 3/6/08 at 04:46 PM |
depends on the rad I suppose
I have a polo rad and the cap on that vents (did vent!) under pressure and just dumps the overflowing fluid onto the floor....
Dave
