jabbahutt
posted on 6/6/08 at 10:15 AM |
adjusting castor
Morning all
Just trying to sort out the front wheel toe/camber and self centering. I've been reading the threads about toe out for SVA and that castor is
the greatest force for self centreing.
Would I be correct that turning the mushroom insert adjusts the castor? apparently the more castor the better the self centring.
So for max castor with the MK set up should the offset hole in the mushroom point forwards as per the original recommended set up?
Thanks for any help
Nigel
mookaloid
| posted on 6/6/08 at 10:39 AM |
jabbahutt
| posted on 6/6/08 at 10:48 AM |
none for me thanks, it's dinner time in half an hour
Some assistance about the postion of the mushroom though would be great
mookaloid
| posted on 6/6/08 at 10:52 AM |
The holes in the mushrooms go towards the front
Mark
mad-butcher
| posted on 6/6/08 at 11:19 AM |
What time do you get up of a morning, and have you got a completely flat surface to work off, I work nights at menzies distribution (other side of
motorway to cheshire oaks
Tony
nitram38
| posted on 6/6/08 at 11:30 AM |
Do a search!
There is only one way to get the castor right for centering and that is remake your top wishbones.
thepest
| posted on 6/6/08 at 12:20 PM |
Yep... I ended up with 2 sets of top wishbones
mad-butcher
| posted on 6/6/08 at 01:27 PM |
Yes we are all aware of the short fall in design of the 7 were stuck with it and have to work our way around it and make the best of what we've
got, mine handles like a dream on the track and I wouldn't change it, but mr SVA man knows best
tony
| posted on 6/6/08 at 04:28 PM |
You can use the offset mushroom to adjust the king pin inclination but not the caster.
Put the hole towards the inside and for a given camber angle king pin inclination is increased.
Put the hole to the outside and king pin inclination after the camber is adjusted will be decreased.
Increased kingpin inclination will increase the self centrin effect BUT use with care.
snapper
| posted on 6/6/08 at 05:12 PM |
Pumping up the front tyres to a much higher pressure than you would normally use say 30 to 35psi instead of 18 to 20 will also help.
I eat to survive
I drink to forget
James
| posted on 6/6/08 at 05:27 PM |
Seconded!
Nigel,
Setting your top wishbone as far back relative to the bottom wishbone is the way to maximise caster.
HTH,
James
- Muhammad Ali
