iscmatt
| posted on 9/6/08 at 10:02 PM |
MK shortened sump capacity
how much oil do you put into your MK shortened sump??
Just out of interest, thanks
eccsmk
| posted on 9/6/08 at 10:32 PM |
for what engine would that be ?
indykid
| posted on 9/6/08 at 10:36 PM |
i'm gonna take a wild stab at a pinto as it says in his profile at the left of his post.
as for capacity, i don't know. i fill it to the line on the dipstick. it's probably a bit less than 4 litres though from very approximate
memory
tom
eccsmk
| posted on 9/6/08 at 10:58 PM |
memory
tom
well spotted
ill go sit in the corner again
iscmatt
| posted on 10/6/08 at 07:07 AM |
sorry yeah, for a pinto
bob
| posted on 10/6/08 at 08:45 AM |
If you have the version with the wing on the side to make up the lost capacity from the chop i would go with the manual, when my pinto was in with a
sump altered by martin keenam i ran 3.75L from empty.
bob
| posted on 10/6/08 at 08:46 AM |
the old sump
iscmatt
| posted on 10/6/08 at 09:15 PM |
Ah, mine does not have the wings so i am presuming i need to reduce the amount going into the sump, is there any proven technique in finding out how
much oil to put in or is it simply a task of trial and error
indykid
| posted on 10/6/08 at 11:06 PM |
go with the dipstick. the max is max for a reason and the min is min for a reason.
you just need to check it more religiously as there will be less capacity betwen max and min.
tom
iscmatt
| posted on 10/6/08 at 11:30 PM |
tom
I was unsure though that my dipstick has been adjusted to suit the shortened sump which may be contributing to my oil problem - different thread.
bigpig
| posted on 1/10/08 at 08:46 PM |
I'm taking the assumption that the dipstick measures somewhere around the bottom of the crank.
Isn't the oil supposed not catch on the con rods or something to stop it being foamed up?
If it is so then I would guess that a standard dipstick measurement should be correct, but hopefully someone knows for sure.
procomp
| posted on 2/10/08 at 07:36 AM |
Hi.
As mentioned re the dipstick. I doubt they will have chopped enough of the dipstick to eliminate the MAX marking. In wich case you still fill to the
MAX mark as origanly done by Ford. As this will give the oil a level that will be safe to run with sufficient clearance to the crank.
IE you are effectively measuring from the crank to your oil level rather than the base of the sump to your oil level if that makes sense.
Cheers Matt
