Matthew
| posted on 9/12/03 at 05:24 PM |
propshafts
Do MK Engineering balance modified propshaft and if so how much does he charge.
alister667
| posted on 9/12/03 at 10:42 PM |
They way it works is you supply a sierra propshaft they modify it (add slider, change length) for 65 quid I think. I don't know if they would
balance a pre-made shaft. Personally I would go for a professionally made unit rather than a home built one.
Matthew
| posted on 11/12/03 at 12:54 PM |
The prop shaft is half manta half sierra as running vauxhall engine I have had it proffesionally done locally just need it balancing.
