paulmw
| posted on 11/7/08 at 08:09 PM |
Team Dynamic Offset..... again
Following my previous post I cant find on the wheel where it says the ET. The wheels still dont look right and rub the body quite badly over bumps.
I'm sure there not a 38 ET as specified. I bought them from a good source so should I send them back
Paul
paulmw
| posted on 11/7/08 at 08:11 PM |
pic2
adithorp
| posted on 11/7/08 at 09:32 PM |
Have you measured them Paul?
Easiest way (there's a few methods) is put a ruler/streight edge across the inner rim and measure the depth from that to the mounting face(A).
Then do the same from the outer rim(B). Subtract one from the other and divide by 2. So (A-B)/2= et
adrian
stuart_g
| posted on 11/7/08 at 10:11 PM |
Mine have the ET dot punched into the inner part of the rim.
welderman
| posted on 11/7/08 at 10:15 PM |
all of the alloys ive had have had some form of marking on the stating off set
Thank's, Joe
I don't stalk people
indykid
| posted on 11/7/08 at 10:20 PM |
that looks like mine. mine are et38 but 205 tyres. i've had to take alllllllll the return out of the outside of the arches and they still catch
slightly.
mine are pro race 1s and when i bought mine they were cast and milled to order. all cast to about et14 then milled back as required. the et was
written on in permanent marker.
the pro race 1.2s seem a bit more mass produced but i'd still not be surprised if there were individual castings for individual offsets for it
to actually be marked on the wheel.
i'm reasonably confident those in the picture are et38 anyway
tom
indykid
| posted on 11/7/08 at 10:25 PM |
like this
tom
| posted on 12/7/08 at 01:21 PM |
Put some negative camber on the wheels and take the edge off the rear arch. That should cure it.
Phil
PAUL FISHER
| posted on 12/7/08 at 01:35 PM |
As Phil says you need 2 to 3 degrees negative camber on there,toyo recommend you run around 3 degrees on the R888,if you check out there webb site,I
run the R888 and I think the Indy R chassis feels with better this amount on the rear,also the 195 R888 is wider than 195mm,if I recall its just over
200mm wide,so this can also be part of your problem,although I run 205 R888 on the rear of my car on et38 7" pro race 1,2's.with no
problems,
